Sun visor removal?
Old 05-14-11, 11:52 AM
mr29rose
mr29rose's Avatar
Default Sun visor removal?
how to remove sun visors?
Old 05-15-11, 02:04 PM
sktn77a
sktn77a's Avatar
Remove the screws on the triangular mounting plate on the roof and then pull it out. There's a wire going in through the metal rod, unplug that and it comes away.
Old 05-15-11, 05:34 PM
salimshah
salimshah's Avatar
Received 1,055 Likes on 952 Posts
You have to pop/push the triangular piece off to expose the screws.
Salim
Old 05-16-11, 10:41 AM
sktn77a
sktn77a's Avatar
Ah, OK, it's been a while!
Old 05-16-11, 05:53 PM
mr29rose
mr29rose's Avatar
so use force to pop of the triangle piece right
Old 05-17-11, 07:20 PM
sktn77a
sktn77a's Avatar
Yes. You may need a flat blade screwdriver.
Old 02-04-15, 09:43 AM
wheels09is
wheels09is's Avatar
Cool Visor Vanity Lights will not illuminate
Neither light comes on when sliding the mirror cover. There is power all way through the connections. I cannot test the slide switch without removing the fabric and it is glued/fastened so no access. Any suggestions?
Old 02-04-15, 11:11 AM
salimshah
salimshah's Avatar
Check out the bulb or connections to the bulb before trying to get to the switch.
Salim
Old 02-09-15, 09:34 AM
wheels09is
wheels09is's Avatar
Default Visor Vanity Mirrors Not lighting
[Yes, the bulbs are good. I checked polarity and tested the bulb in another socket. All good. I pretty certain that it is the switch in the mirror slide. Does anyone know hot to access this?
Old 04-13-17, 03:10 PM
Tarnack
6th Gear
Tarnack's Avatar
My passenger sun visor is broken. Where should I go to get a replacement at a reasonable place?
Old 04-13-17, 05:43 PM
salimshah
salimshah's Avatar
try the fleabay.
Salim
ThumperPup
ES - 5th Gen (2007-2012)
12-22-17 02:14 PM
schack
11-19-14 07:40 AM
ManXP
05-16-13 07:42 AM
psls400
IS - 1st Gen (2001-2005)
06-02-06 04:09 PM
LS Boy
GS - 1st Gen (1993-1997)
11-09-04 09:04 AM
Quick Reply: Sun visor removal?
