What oil are you using right now?
#77
Here's a question: I had a '01 RX300 FWD that finally died at 249k (transmission). I now have another '01 AWD with 161k that has probably had regular oil in it. I have a gallon or so synthetic left I'd like to use. Should I mix it with regular oil or run it straight? I'm thinking mixing it with regular oil would be the best bet.
I could have been taught improperly, but why take the risk, is my thought!
Bear
#78
Not to be harsh but...you were taught improperly.
Synthetic oil isn't like some other animal here. It's still oil. Usually with a much better additive package and refined further than standard conventional oils.
I work for one of the biggest motor oil companies in the world, so I hear these old oil myths all the time. Some of which had held truth 20 years ago but oil has come a LONG way in 20 years.
#79
As a mod, I cringe when I see a thread on 'which oil is best' which 'fuel grade is best' etc. I think this thread is about to turn ugly. Please prove me wrong. I would urge all to show maturity and class and not let this thread end up as locked.
As you compose a reply, please, please review it before you hit the 'submit' button. Your post/reply will be well received if it has good reasoning behind it. Mature conversation will be (and is) appreciated by members/readers.
Salim
Salim
#81
Well, then I stand corrected! Thanks Eric, good to know! What with the RX300 having the potential to be a slow leaker, and mine certainly falls into that category, it's good to know that in a pinch I can throw in some conventional to get me through and not worry about mixing issues!
And Salim, I hope you weren't concerned that I was going to get ugly about things! I have plenty of that physically without it extending to my brain and mouth!![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Hope everyone has a great Monday... I'm wearing black, in mourning for the loss of this past weekend.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Bear
Bear
#82
I was in no way being confrontational. After reading my response I can see how it could be not well received. My apologies!
Glad you found a cost effective way to get by in a pinch!
#83
Thank You.
This is a wonderful board.
When I was approached to be a Mod it took me a while to say Yes.
It is folks like you that I have not regretted saying yes.
Salim
Salim
#84
I'll second that. It's been a nice experience here on the first gen RX board. The maturity of our members really shows. Which is basically what makes or breaks a board. Happy to be a part.
#85
Hi i am using conventional oil in my rx 300 2000 model.she is cosuming 1 quart every 750 miles.Question should i convert to synthatic oil like mobil 1 or castrol . or any advice is highly appericiated.There is no leak though i found beneath the block is messy .
#87
Salim
#88
Look up the links here for Auto RX. It is a great product and can rejuvenate seals as well as clean your engine.Many users here have used it and have gotten good results.
Good Luck.
Larry
Good Luck.
Larry
#89
So what should be done like putting some leakguard .or I check the leak then go further.
KingNasGS4
21
03-24-09 08:51 PM
