running not to well, i have codes (need help)
Old 06-27-11, 11:51 AM
jevanof
jevanof's Avatar
Default running not to well, i have codes (need help)
I have a 1999 RX300 with 140K miles, its never let me down until yesterday, I went to drive it and it ran ruff, I am getting codes P0300, P0302, P0303, P1305 and P1025, After reading threads on this site I replaced the OCV and all the plugs, the gaps are correct to. I am a little worried if I buy coil packs it might not fix my problem and I cant really afford to keep replacing parts that will not fix the problem, if anyone has some insight please let me know
Joe
Old 06-27-11, 01:23 PM
jevanof
jevanof's Avatar
also i just disconnected the battery, switched coil packs from 2 to 6, re connected the battery, drove it around and pulled the codes and I am still getting misfire on bank 2 and 3, I am really confused any help would be greatly appreciated
Old 06-27-11, 01:33 PM
salimshah
salimshah's Avatar
Received 1,072 Likes on 965 Posts
Now I am confused .. bank3?
Spark plug order
Cabin
1 3 5 <= Bank 1
2 4 6 <= Bank 2
Front
Salim
Old 06-27-11, 01:53 PM
jevanof
jevanof's Avatar
ok maybe i said that wrong, i am getting the exact codes as i did before i swapped coil packs.
Old 06-27-11, 04:42 PM
jevanof
jevanof's Avatar
i think i may have figured it out, I took coil pack #2 out of the cylinder plugged it back in turned the car over, no spark, checked #3 and I got a spark, I then swapped coil packs from cylinder 2 to 3 and still no spark, so I think I found a bad coil pack. I am going to get a new one tomorrow, any ideas if I should one from auto-zone or the dealer?
Old 06-27-11, 05:27 PM
salimshah
salimshah's Avatar
Spark plugs, coil-packs and all sensors should be OEM. <= period
Salim
Old 06-27-11, 06:42 PM
hypervish
hypervish's Avatar
Like salimshah said, OEM! Don't skimp on essential parts.
Old 06-28-11, 12:38 AM
code58
code58's Avatar
Here's a 3rd to that!
Old 06-28-11, 10:42 AM
jevanof
jevanof's Avatar
ok, when I changed the plugs I installed AC Delco, I will order a stock coil pack and new stock plugs when the money hit the bank, thank you
Old 06-30-11, 06:51 AM
jevanof
jevanof's Avatar
Changed the coil pack, everything is working great, thanks for you help
Beto18
RX - 3rd Gen (2010-2015)
05-14-22 09:48 PM
Rokas
07-08-18 12:32 PM
diplomat1
10-01-16 09:49 PM
jadeaudio
16
12-16-12 10:42 AM
jayco5
05-06-06 07:49 PM
Quick Reply: running not to well, i have codes (need help)
