front passenger door can't be locked or unlocked...
so ya my dad told me that when he closes the door from driver side all the doors click in n lock or unlock but he noticed that the front passenger side doesn't lock or unlock..he has to do it manually..same thing happens with the remote key too..i was thinking of fuse but the window is able to roll up and down..weird..does any one of this?any suggestions?
Door lock actuator is broken, check:
https://www.clublexus.com/forums/rx-...-actuator.html
Yeah, this has to be the most FAQ for RX300s, ever.
Door actuator. To clarify, it's either dirty or broken.
There's a guide on here that shows you how to easily clean the existing one - if that doesn't work you have to either replace or bypass the existing actuator. There's a few ways it can be fixed, I suggest checking out all of them and seeing which one you feel most comfortable doing. Unfortunately, none of them are easy.
My front driver side has been out for over a year and I haven't fixed it, for this very reason. It's going to be a major PITA to fix.
Depends on the dealer (Toyota or Lexus or independent) but will probably run between $450.- $650. parts and labor. Lexus most likely being the high one on that list. If there's any way you could do it yourself I would sure suggest it. There are plenty of good instructions for whatever method you choose, just do a search.
