Old 12-15-14, 04:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
RX300: DIY door lock actuator fix write-up
Old 07-29-15, 10:02 PM
  #256
carguy07
carguy07's Avatar
Hopefully you guys all looked at the piggyback method to fix these and made the choice to repair them the arguably "right" way. The piggyback worked great for me and countless others. Just want to make sure you guys are aware of it when doing this repair.
Old 08-03-15, 08:03 AM
  #257
steelgtr
steelgtr's Avatar
My DS door stopped working but occasionally will still work; more like sticky than dead? Is it always the motor?
bob
Old 08-03-15, 09:14 AM
  #258
salimshah
salimshah's Avatar
Received 1,098 Likes on 988 Posts
bob
Only detailed testing can tell. Based on age/use one can make an educated guess.
Salim
Old 08-04-15, 10:53 AM
  #259
marksm
marksm's Avatar
Originally Posted by Aqueon
Which wires did you reverse? I'm a little hesitant to cut blindly, and - at least as far as I can see - they aren't labeled. If I can find my multimeter, I could probably find out, but I'd appreciate your insight.
I'm trying to get my wife's car fixed up before we go out of town for vacation...
I reversed the motor wires. But apparently there's more going on than just the direction the motor spins so it refused to operate correctly mechanically.
I ordered the motor housings from Ebay and they work as they should. but I still need to replace the rears because now when I use the key to unlock the alarm goes off. I suppose it's because the right rear is still reversed and it doesn't get the correct signal to the computer.
Link to Right front; http://www.ebay.com/itm/NEW-99-03-LEXUS-RX300-PASSENGER-FRONT-RIGHT-DOOR-LOCK-LATCH-ACTUATOR-/331602388182?fits=Model%3ARX300&hash=item4d350ae4d6&vxp=mtr
Old 08-20-15, 09:46 PM
  #260
10lexISR6
10lexISR6's Avatar
Default I've replaced all 4 lock motors now
So in May of 2013 the front right door lock motor kicked the bucket and with the incredible step by step details I replaced it successfully. Zero problems to this day. Last year the right rear door lock started acting up and eventually quit. Now recently the driver side front door lock kicked the bucket so it's time to address them. I went ahead and did both the door with the bad locks but since there was only 1 door left, wth I knocked it out too. They all work so strong and perfectly. I absolutely love being able to repair these locks for so little money and couldn't stress to anyone else to do it. It's so easy. Thank you everyone for your feedback. Much appreciated.
Old 08-31-15, 08:04 PM
  #261
jbsocal
jbsocal's Avatar
Angry Help needed
Did the mod, I test the door manually multiple times with key everything works. Try the electric it works great. Then trying it manually it doesn't work to unlock or key. I read something in a post about the spring under the gear. I looked at it and it looked good. Does anyone have a picture of what it should look like? Or maybe another problem?
Old 08-31-15, 09:44 PM
  #262
salimshah
salimshah's Avatar
You did the mod or the fix. Mod would be a work around while the fix would be to replace the bad motor.
Since your problem is with the mechanical part, I would check if the links and the cable are hooked up properly. The nylon locks are not dislodged.
The next step may involve removing the actuator again and making sure it was assembled properly and do the dry run (yanking the cable and pushing down on the plate.
Just make sure you do not button up the door panel till everything is verified by couple of days of testing.
Salim
Old 08-31-15, 09:51 PM
  #263
jbsocal
jbsocal's Avatar
I did the fix. I believe the issue might be
Someone asked after the repair they can’t operate the door lock manually. The reason is because after you open the actuator module, you can see there is a circular spring sitting inside the race trace of the clamshell. The circular spring has an ‘L’ bend on each end. What happened to me was that after I opened the module, the spring sat loosely inside the race track. I didn’t know it was a problem and after I put everything back I wasn’t able to operate the door lock manually, either. I finally realized that the ‘L’ bends need to tie to the two opening edges of the race track, by pulling the spring about 3/4 turn. Without the spring, after the motor is activated and turns the gear, the gear will sit at a position so that the lever (which is hooked up to the ‘bicycle brake’) won’t be able to turn the gear in the other direction. The spring pushes the rotary gear back about 1/4 turn so that the lever can work in a ‘free zone’ of the gear. So remember to check if the spring is sat properly in the race track.
but I do not know what it should look like or where the gear needs to be.
Old 09-01-15, 10:09 AM
  #264
salimshah
salimshah's Avatar
We need pictures of the innards. So open it up again and send photos. That will help jog our memory. You can also try PM to the person who posted the fix.
Salim
Old 09-01-15, 01:51 PM
  #265
hypervish
hypervish's Avatar
Perhaps this video at 5 minutes 40 seconds will help you see where the spring should be located:
Old 09-01-15, 02:32 PM
  #266
jbsocal
jbsocal's Avatar
Default Thanks
Thanks!
So the gear needs to rotate 3/4 not 1/4 quarter. In my gear the bottom slot is in the 1 quarter below the smiley face. It looks like that might be the issue.
Old 09-01-15, 04:46 PM
  #267
jbsocal
jbsocal's Avatar
Default Still stumped
When I run the autolock the spring gets tighter and tighter as you lock and unlock than manual doesn't work at all because the gear is too tight
Spring below gear
Old 09-06-15, 12:19 PM
  #268
shumif1
shumif1's Avatar
Awesome thread , just did my drivers door actuator motor. Took me about 30 min.
Old 10-12-15, 02:17 PM
  #269
cjj2533
cjj2533's Avatar
Manual Operation Fix
After replacing the motors in three doors I found two that didn't work manually after powering them up. I pulled them out and found that not all motor shafts are created equally. It appears that the worm spindle (pointed out by the screwdriver tip) was touching the motor shaft and causing a binding resistance (when installed) that the spring could not overcome. I ground down the worm spindle just enough to avoid contact with the motor shaft. After reinstalling the motor and worm I was able to clockwise spin the worm gear using my small screwdriver and watching the spring return it back without any resistance. I completed the reassembly and now all my doors work as they should.
Worm spindle
Old 10-12-15, 08:49 PM
  #270
10lexISR6
10lexISR6's Avatar
Worm spindle
Why is your worm spindle so long? I did all 4 doors and none looked like that. All mine fit without hassle. Weird.
Quick Reply: RX300: DIY door lock actuator fix write-up
