what is a/c refrigerant line looking glass for?
Hey Forum, I noticed in front of and halfway near the top of the radiator
there is a (refrigerant?) line that runs all the way from left to right,
and on the line is a little glass that you can look inside and see the liquid in.
What is this glass for? Can I measure the refrigerant levels
using this?
Thanks !
using this?
Thanks !
It is used for measuring...to a degree. No pun intended. While ultra-rudimentary, it can be useful for initial diagnosis.
When the system energized, you should see a puff of bubbles, followed by liquid. If no puff of bubbles, it over- or under-filled, about 99.999% of the time, it's the latter.
If there are bubbles all the time, it's a bit low. You really should have gauges to measure the pressures, however. If for no other reason, to make certain everything else is performing as it should be.
BTW, the a/c is blowing cold. I had it checked 2 years ago, and they said it was perfectly fine. If this glass can be used as a way to avoid getting periodic a/c checkups, I can save
that for beer money :-)
Johnhav430
09-06-17 11:40 AM
Emster
06-17-07 04:51 PM
2010, 350, ac, change, glass, gx470, lexus, line, lines, refrigarant, refrigerant, refrigeration, refrigirant, rx, sc300
