RX to sit for 6 months/Synthetic or Dino
Folks, subject says it all. My RX300 is in Arizona and will be sitting for 6 months. Would I be better off with synthetic or dino oil? It will be in a garage as well.
thanks in advance for any input.
JBL
JBL
Thanks - geez I don't want to get into that whole "Should you use Synthetic or Not" discussion, as I have heard some folks have experienced leaks, etc...I know that Synthetic was probably they way to go and was not suprised by your answer but I just DO NOT want to have to worry about stupid stuff liek are my seals going to leak, etc...
Decisions, Decisions...
May not be a bad idea to put a jack stands at each corner, just enough to take the weight off of the tires otherwise it could take a while to work those flat spots out. I'm pretty sure your supposed to disconnect the battery as well.
Now I connect the BT and forget about it.
JBL
I actually wouldn't keep the car off the ground for so long. Sure it might prevent flat spots on the tires, but it's not good for the struts to be hanging for 6 months. It's alright when your working on the car for all 4 struts to be at full height but you don't want them to be open to their full extent for 6 months.
I think one of the concerns when letting the suspension hang like that is that the shafts on the struts can corrode and ruin the seals in the struts when they are pushed back in. The bushings also tend to take a set (kind of like a flat spot) and can get damaged when the car is lowered back down. Could just be an urban myth, but makes some sense to me. I have stored cars for years and never had a flat spot anyway.
The strut is not fully extended? The axle will extend to the length of the spring which is holding the weight of the hanging axle, so if the strut were then removed it would extended even further than this storage position. The strut is an oil or gas filled tube with rubber valves to slow the flow of oil/gas from bottom to the top. It makes no difference where in the oil/gas the valves are positioned for storage. The struts are fully compressed when shipped from the manufacturer and remain this way for several months and are not damaged. So, I would still take the weight off of the tires.
I have had people come into my uncle's shop needing new struts all around because they stored there hot rods too long with the suspension hanging. My uncle is a mechanic, he's seen this happen many times.
You will not get flat stops on a tire from just 6 months if you have proper air pressure. No reason to risk $1000 worth of parts and labor for struts.
Plus, it can also cause unnecessary weight on the control arms, bushings, etc.
However, it is safe to lift the car up a little, just enough to take pressure off the tires. But, not too much that the tires are lifted off the ground. << But, this isn't necessary at all and definitely not for just 6 months.
Truth be told the last time I left the car, I did not jack it up so that all of the wheels are off the ground, rather, the tires are still touching the ground but I would say that 3/4 of the weight of the car is supported by the jacks, and it has been sitting that way since the beginning of June.
jonas's RX
RX - 1st Gen (1999-2003)
01-15-16 11:43 AM
