Cannot remove PCV valve
I am trying to get my PCV valve off, and it just won't come off. The little "L" shaped hose came off just fine, but I have pulled and pulled, and even started to pry it up with a flat head screw driver and it won't budge. I thought maybe it was a screw on type (I think I read somewhere where they started going to a screw on type valve) so I spun it around probably a hundred time counter clockwise, but it just spins freely and never unthreads itself (assuming it even has threads, which I don't think it does. The grommet at the base of the valve is very brittle and when I tried to pry off the valve with a screw driver, some of the grommet broke off. Any advice on how to remove this thing???
Yep, positive. I've looked through many posts on this forum, specifically the DIY spark plug thread by Lexmex. He has pictures of the PCV valve and hose removal, and there is no doubt about what I am trying to remove. I suppose I need to just keep prying it off, so I'll continue on with that process.
Ok, I finally pryed it out. It was pretty oily and seemed to almost have baked on oil flakes. The grommet was very brittle and kind of broke apart when trying to remove it. I think a few small chunks of the grommet fell into the hole that goes into the engine. Is this a really bad thing???
PS A partially clogged PCV valve and/or hard (non-sealing) grommet will cause your valve covers to leak.
I had a problem removing Grommet myself, which fell inside the hole. It took me hours to remove the grommet but finally remove. I used L-long-nose plier and flat screw driver. And Vacuum to remove the small pieces that left behind. Use a vacuum that you can bend the end like fish hook. Good luck
