Transfer case clarification
Old 08-24-11 | 05:42 AM
ownpace's Avatar
ownpace
Default Transfer case clarification
Apologies at the outset, I'm a newbie (bought my AWD RX300 4 days ago)and got confused because the term "transfer case" is used in more than one way, so I would appreciate if someone could clear up the following......
On TunedRX300's excellent sticky "RX300 AWD Transmission Fluid, Pan, Filter Change" we are changing the fluid for the automatic transmission and the front differential (for "front differential" the term "transfer case" is used). Is photo 1 of the front differential with a hex key in it?
Then on LexMex's equally excellent sticky "Rear differential/Transfer case fluids (for those of you with an AWD RX300)", we are changing the rear differential fluid and the transfer case fluid to the rear drive. Is photo 2the transfer case (which is a different transfer case to photo 1)?
Many thanks and apologies again!
Attached Thumbnails Transfer case clarification-front-differential.jpg   Transfer case clarification-transfer-case-to-rear.jpg
Old 08-24-11 | 05:47 AM
thomas1's Avatar
thomas1
the first picture shows the transaxle which shares tranny fluid...the second picture is the transfer case which uses gear lube.....
Old 08-24-11 | 09:22 AM
hypervish's Avatar
hypervish
x2, as to what thomas1 said.
Old 08-24-11 | 10:18 AM
sbtots's Avatar
sbtots
Actually, I'm planning on doing this job and was wondering the same thing, I'm on the site just to clarify this point so I must say thanks for the replies.
Old 08-24-11 | 01:24 PM
Lexmex's Avatar
Lexmex
Super Moderator
Let me know if you have any more questions about this process.
Old 08-24-11 | 03:35 PM
salimshah's Avatar
salimshah
Just make sure you can open the filler hole of the rear diff before attempting to open the drain. Lots of horror stories about stripped filler and lube drained out
Salim
Old 08-25-11 | 06:22 AM
lexus114's Avatar
lexus114
Salim
Absofrigginlutely!!
Old 08-25-11 | 10:06 PM
sbtots's Avatar
sbtots
Guys, I've did it! I've changed tranny fluid, filter, transfer box fluid, front and rear diff oil. Could not be done without your help thanks a million.
Dukenukemx
11-05-20 05:02 PM
BinaryJay
08-17-11 10:52 AM
dfish
03-31-07 12:53 PM
autodriver
Maintenance
05-24-04 11:00 AM
Quick Reply: Transfer case clarification
