Best price on air servos? And where?
I have cleaned the air servos a couple of times already.Lucky on one. The one that changes the air from the head,to mid, then to feet, still makes noise. What web site has the best price so far? Does anyone have a good picture with arrows pointing to each servos with part numbers. Much thanks
I can tell you why the servo still makes noise. Lexus uses tiny Mattel like motors in the servo's and door locks. They are made in China (probably nothing wrong with the Chinese quality) but I have taken the motor apart and they are simply TINY. The brushes wear out (understandable) and then the motor has no real power. It has to overcome an overcenter spring that keeps it in that position once the motor puts it there, otherwise the incoming air will tend to push it back. The poor worn out brushed motor simply isn't able to overcome the rather adaquate spring pressure of the overcenter spring, so it sits ther and chatters like an old man trying to roll a bolder up hill. You release the overcenter spring and the motor does no chattering and easily pushes the door to where it needs to be with no noise, but it won't stay there for the ressons already mentioned. It's a rip off because when you can find those little motors (you generally have to buy some quantity) they can often be purchased for $1. ea. I don't honestly know of anywhere aftermarket that sells the servo's. Best place to get a sevo would be one of the Lexus dealers that sells discount online. I have tried to repair the motor once I had it apart (used to doing this kind of thing) but when the TINY brushes are worn out, there isn't much you can do.
Salim
I do RC airplanes. I can get the motor. It is just the gear pressed on the shaft that is hard to replicate.I guess i could transfer the inside and use the outer part? You are right. It is a rip off. And from what i see on here, all RX`s will encounter it. Could you imagine the money the dealers have made. Not everyone like us can do our own work.
Salim
Puttster
RX - 1st Gen (1999-2003)
09-20-16 10:07 AM
GStatus
01-07-16 10:44 AM
salimshah
10-29-11 03:54 PM
