lamp failure sensor
#31
I have seen the video on You Tube to remove and fix the module but he doesn't show how to remove the 12volt auxiliary port in the trim panel so the panel can come out. It won't budge! Does anyone know what's holding it in and how to remove the port?
PS: the video is here:
Thanks,
AlanVR
AlanVR
#32
If the trim plastic has not turned hard you can bend it enough [if has hardened over time dont bend as it can break].
From memory there is sliding mechanism that locks the 12v socket.
Salim
Salim
AlanVR (11-29-18)
#33
Thanks Salim. After I read your last post I found this thread " How to remove rear power outlet" and captdalton has pictures! His post #10 on that thread.
Thanks and blessings!
AlanVR
AlanVR
#35
All done! I used the 3 wire splice recommended and its good to go. What a pain to get to but at least it can be done. The more you learn the less there is to fear!
Blessings and thanks to all!
AlanVR
AlanVR
#37
The filaments share a common wire, the green/white wire. the green/red goes to one filament while the green/yellow goes to the other filament in the same bulb.
soyhead
02-08-06 04:39 AM
