VSC Light by itself, no check engine light
I have a rx300 yr 2003, and this week the VSC light came on all by itself. I check for codes and I guess because the check engine light is not on, I didn't get any codes. When I start my truck, all the lights shut off, including the VSC light, but once I put it in gear (drive or reverse) and start driving then the VSC light comes on. Any suggestions on what to do. My SUV has about 115,000 miles.
Thanks in Advance
Larry
Thanks in Advance
Larry
I think I would disconnect the battery and see if it comes back. If it does see if the info in these threads helps.
https://www.clublexus.com/forums/rx-...ing-light.html
https://www.clublexus.com/forums/ls4...c-vsc-off.html
I think the zero point calibration can fix this too.
Is there any update to this?
I am having a yaw weight sensor problem that a zero-point calibration did not fix. They are saying the sensor is good, and are baffled why the VSC light is still on.
