Rx300 Battery Problems
Old 10-09-11, 12:37 PM
Francisco1
Francisco1's Avatar
Question Rx300 Battery Problems
I have a 1999 Rx300. It was running fine last month but it wouldn't pass the smog check. The CEL kept lighting up and the codes P1155 And P0171. And now the battery the car is just burning the battery. I think it might be the ECU but im not certain, any idea what it could be?
Old 10-09-11, 01:23 PM
hypervish
hypervish's Avatar
Welcome to Club Lexus!
What do you mean by the car is just burning the battery? The code is for a oxygen sensor.
Old 10-09-11, 01:45 PM
salimshah
salimshah's Avatar
Received 1,081 Likes on 973 Posts
Car batteries are relatively cheap. Have the charging system and the battery tested at any auto shop that sells batteries.
Was any thing done to the RX that might have created the battery problem?
Salim
Old 10-09-11, 04:59 PM
Francisco1
Francisco1's Avatar
Salim,
thanks for the tip. and nothign was done to the rx that we think could have created this problem
Old 10-09-11, 05:01 PM
Francisco1
Francisco1's Avatar
hypervish,
thanks for the welcome. the oxygen sensor was changed but the battery looses all the charge within 5 to 7 min. and it wont recharge them. i switch batteries 3 times already and the same problem continues
Old 10-09-11, 07:52 PM
sktn77a
sktn77a's Avatar
Would appear to be a short somewhere. Usually in the starter or alternator circuitry when its that bad. Surprized it isn't sparking all over the place if it's draining the battery that fast.
Old 10-09-11, 07:58 PM
salimshah
salimshah's Avatar
Originally Posted by Francisco1
Salim,
So you are either not getting charged by alternator or there is a load that is bad. Do you have any aftermarket accessory? My second suspect would be the alternator. To find out a bad load, you can pull the fuse out. 7 minutes to discharge a good battery, is pretty horrendous load.
Salim
Old 10-09-11, 11:47 PM
code58
code58's Avatar
Salim
If you can discharge a fully charged battery in 5 to 7 minutes, there must be a whole lot of smoke rolling there somewhere, unless you are using flashlight batteries in it. That's just CRAZY!
DaveInMesa
05-07-16 08:48 AM
DavidinCT
03-19-10 08:03 PM
metrostle
17
08-02-09 02:21 PM
RHS
03-18-06 11:06 PM
renn1
10-23-05 11:36 PM
Quick Reply: Rx300 Battery Problems
