Replace rear rotor DIY w/pic?
Hi guys,
Sorry to have to open a thread for this. If someone can give the proper link, this can be deleted afterwards.
I kept searching for DIY with pic on how to replace not just the rear pads, but also take off the rear rotor. As I read in some threads, it require some alignment and I would really love to see some pictures to make sure I know what is needed.
I am planning to order the rear rotors and rear pads soon to replace the OEM stufff.
Thanks all!
Thanks all!
https://www.clublexus.com/forums/rx-...ml#post5450688
Not that much to it. Just an old school drum brake set up for the parking brake inside the rotor. I never touch the star wheel and my rotors fall right off and my parking brake works fine.
I began looking for the rotor and pad online to see if I can save some money instead of going with Toyota parts.
I found this rotor which is said to be exact fit for RX300, but it mentioned that it has the drum in hat parking brake.
I was wondering how I can change the drums too.
It is two in one piece.
If nothing is wrong with the parking brake shoes, the drum-disc should come off easily. If the parking shoes have cut a groove inside the drum portion, you will have to manipulate the star wheel. If you have not worked with the drum brakes, I would suggest stop and take it to a mechanic. If the disc-drum comes off easy, go ahead with the swap. Do put a breathing mask before you take the drum off. All the wear off is concentrated inside the drum.
There are many posts on a size mismatch between AWD and FWD. So make sure before you purchase and measure outer-radius before installation.
Salim
Salim
Thanks for the reply.
Looking at the link that was provided by another member.
It seems like it's not hard to take out the rotor.
I do question if the rotor I want to order has the rotor and the shoes separate.
http://www.jcwhitney.com/professiona...d=d1391y2001j1
This is the one I'm looking at.
It just that I have not seen any DIY on how to change the shoe, which I read that it most likely don't need replacement.
I do however have to look at how to adjust the parking brake cable because it seems to have some slack now and not as tight as before.
update:
I asked the vendor and it seems like this is just a barebone rotor and that it's "compatible" with the hat in drum parking brake system. That makes it more clear to me now.
update:
bklynchris
05-28-13 08:33 PM
