Safe to use 2004 Camry Valve Body in 2001 Rx300?
Hi,
Since the 2004 Camry V6 used the same transmission as the 2001 RX300, is it safe to use the valve body from the Camry and put it in the RX300?
Thanks
Thanks
Ooooooooh.
Brave, but I like it.
There's only one way to truly find out. The worst that can happen is you have a transmission full of neutrals....
Most likely the part numbers would be different, even if they cross reference to identical part.
How about purchasing the Toyo part and walking over to Lexus dealer and compare. If the are the same, you are good to go if not, return the Toyo part.
Note: Some parts (specially the electronics parts) are non-returnable and some places may require a stocking fee. So check before purchasing.
Salim
Salim
I'm seeing part #'s that are the same for some of them. 35410-48011
http://www.toyotapartszone.com/oem/t...410-48011.html
http://www.toy----odiy.com/parts/p_U...PGKA_3512.html
delete the --- in the address, it's blocked for some reason on here
x2. And, why mess around with something that could lead to transmission failure. The valve body plays a large part in the transmission (obviously...LOL), and messing around with parts that aren't designed for it isn't something I suggest you do. It can be a very expensive mistake...
Super Moderator
The U140E (2WD) is the same for the 2004 V6 Camry (not the 4cyl one) and the 2WD RX300, 4WD RX300 has the U140F tranny, http://en.wikipedia.org/wiki/Toyota_U_transmission
What's a better option? rebuild the valve body? Does anyone know of a good rebuild kit? or valve body from Camry or Brand new one? Thanks
ganglandstyle
RX - 1st Gen (1999-2003)
03-11-03 04:59 PM
