new member hello, and HELP
Just joined and I guess a shout out howdy is in order.... I'm also in need of some help..
I just bit the bullet and replaced 2 coils, spark plugs and valve cover gaskets,,, phew, talk about aggevating., anyway took it to the dealer and they said I needed all those things (which I did) but the problem is the CEL it has been on for some time now and keeps giving me all kinds of codes besides the one's I took care of. What's the best way to fix this problem...
As of now, after I did all that work, I replaced the O2 sensor on the back bank because it was giving me a lean code, now the latest codes are:
( P0171 system lean front bank)...
(P1155 fuel ratio sensor, bank 2 sensor 1)
P0125 coolant temp. sensor)
a lot of these codes were there before I started, so I don't think it was something I did...
could 1 thing be causing all these codes or do I have to replace all these sensors too....
any help will be apreciated
I think you just need the front air fuel sensor and you will be good to go, ignor the P0125 it will go away when you fix A/F sensor.
OE Denso parts only. Amazon has the best prices.
http://www.amazon.com/Denso-234-9009...=5336108637-20
thanks
thanks for the help,,, sorry I've been a little busy, and I haven't been able to get back with an official THANK YOU. Put the O2 sensor on (great website, saved $100) and sensor worked like a charm. THANKS again
joegreen
19
07-15-15 11:44 PM
