CBEST definitions
CBEST definitions
The FAQ has a great list of CBEST listings (below).
Does anyone have a good definition of these?
Thanks,
Eph
_____________________________________
Wireless Door Lock Remote Control Wireless operation Yes* / No
Door ajar warning beeper Yes* / No
Automatic Lock operation 30s* / 60s
All door unlock (one press) On / Off*
All door unlock (2 presses) On* / Off
Panic Alert Operation On* / Off
Door Lock Control (Key)
All door unlock (key turn 1x) On / Off*
All door unlock (key turn 2x) On* / Off
Illuminated Entry Light Illum time 7.5s / 15s* / 30s
Interior lights illum on key unlock On* / Off
Automatic Lights Sensitivity -40%/-20%/0%*/+20%/+40%
Control logic switchover New(type 1)* / Prev (type 2)
Theft deterrent Passive arming On / Off*
Vehicle horn and security horn On* / Off
Entry delay time switch 0s / 14s* / 30s
Power window system
Key-linked open On* / Off
Key-linked close On* / Off
*denotes default factory setting
Thanks,
Eph
Power window system
RX 300 & 350Z Guru
All of them! :eek: They're pretty much just what they say...here goes.
I don't really know. If it's what I'm thinking; why would you want to disable the remote??
Do you want a beep to sound when the door is open, yes or no.
If you unlock the vehicle and don't open the door, it will lock itself within 30 or 60 seconds, you choose.
Unlock all the doors with a press of the remote unlock button.
Otherwise you press once for driver's door and again for all doors.
look at previous explanation
Allow the alarm to sound (horn honk, lights flash) when you press the panic button
Like with the remote unlock, but instead you are using the key in one of the two front locks.
When you unlock the vehicle, the interior lights will stay on for so long before fading off. Choose, of the three, how long you want. It will turn off after x amount of seconds if the door isn't opened.
Do you want the lights to turn on at all when you unlock the vehicle. The interior lights that is.
Controls when the lights turn on automatically depending on ambient light. Do you want them to turn on when it get barely dark, or really dark. Pick a percentage.
Beats me!
Determines whether or not the automatic lock operation functions.
?? I want the horn on all the time don't I?!?
Not sure here either.
Power window system
Determines whether or not you can use the key to roll down the windows. I don't know whether this means wireless-ly, by holding the unlock button down, or by putting the key in the cylinder on the door and turning it to the unlock position.
Someone can can correct any if they are wrong, and those that I don't know.
Beats me!
Power window system
