Advice on Maintenance
#61
Super Moderator
Thanks Lexmex, I think I'm going to go for the ATP one as it appears to look superior to the others, but can not confirm as its a US based brand like the others etc. However I'm also looking to change the oil as to avoid any sluge issues, can you also recommend a suitable oil from the following, we have Mobil 1, Castrol, Amsoil, Red Line available here so if you could advise on the best possible one and spec then I would be greatful, thanks. I am also going to go for the K&N HP-2009 filter that you use so can just confirm that the size will be okay for the Harrier too? Cheers
My favorite oil is the Castrol Syntec 0W30, for you that would be Castrol Edge 0W30.
I'd put the Amsoil 0W30 a tad behind it, followed by Amsoil 5W30
Then Redline 0W30, followed by Redline 5W30.
For Mobil 1, the the only grades I would consider if I had to were the 0W40 or their 0W30. I had consumption issues with their 5W30.
#62
Hey, anyone know if there is a link with pictures to show how to remove the front headlamps? I've got a condensation on mine and have already got replacements but rather than pay to get it done I wanted to see if it was easy enough to do myself? Cheers
Bgw70
06-09-15 09:19 AM
RA073123
RX - 1st Gen (1999-2003)
16
08-06-08 09:35 AM
