VSC, Trac Off and CEL come on after Battery replacement
Yesterday I had to remove my battery for use on another one of my toys. When I reinstalled it everything seemed fine. This morning after pulling out of my driveway my VSC, Trac Off and CEL lights came on. After reading some similar posts I began checking all the likely causes. Gas cap is okay, hose on the air filter housing is good, and I reset the EFI relay. The lights still come on. I haven't taken it to have the codes read but will do so on my home today. Any other likely causes?
If you can reset all codes and start over.
Salim
Salim
The OBDII scanner is the best way to do it.
Next is to to remove the supply to the ecu for about 15min [you can pull the right fuse or disconnect the battery]. When you reconnect, make sure you do one solid connection and not arc. Removing supply to ecu will result in lost seat memory, radio presets and also pinch protection.
When you go to get the codes read, ask to reset code [some do it and some dont]
Salim
Salim
kim0217
10-30-15 04:02 AM
Lexx2007
03-04-13 11:17 AM
AveryCat
RX - 1st Gen (1999-2003)
08-15-08 06:24 AM
Jedidiah
01-25-08 08:46 AM
