Clicking noise when braking
Old 11-08-11, 03:23 PM
SethP
SethP's Avatar
Default Clicking noise when braking
Just finished a DIY brake job.
When I brake the brakes "click" in fact, I thought I might have a flat tire.
I suspect that it may be that I didn't grease it enough, would lack of enough grease make it this loud?
Old 11-09-11, 08:14 AM
Lexmex
Super Moderator
Lexmex's Avatar
What kind of pads were you using...did they have shims on the back?
Also (did a DIY the other day on this), did you lube the pins/bushings?
Where were you greasing it?
Old 11-10-11, 03:26 PM
SethP
SethP's Avatar
Akenbono ProACT ceramics. And Yes.
I greased everything, including the clips, but I forgot about the primary pin, which you outline in your DIY.
I think I need to go back and do that.
BTW - I did a deep scrub of everything with break cleaner, before relubing it with a silicone lube
Lexmex
49
10-29-16 08:02 PM
mattbruner
Suspension and Brakes
05-31-12 08:01 PM
ap0718
11-29-09 02:39 PM
unit74
10-18-07 10:16 AM
THoon
08-03-07 05:02 PM
Quick Reply: Clicking noise when braking
