danged ol transmission ggrrrrr.
I have a 99 rx 300 and no all about the crappy transmission.Ive had my car about a month.the transmission fluid is pink and dont smell burnt but it sometimes when i stop and start to go itll get up to 2000 rpm before it starts to move and then sometimes its fine.I put it on a machine and the knock sensors bad so it sometimes wont go into overdrive.So i guess my question is do you think im about to lose transmission?If i shut it off or put it into park then drive itll accelerate fine.Kinda puzzles me.
Change that transmission fluid asap, and filter. Sounds like it could be a clogged filter. If you continue driving it in this condition which it sounds like you did, then it might fail.
Super Moderator
Super Moderator
https://www.clublexus.com/forums/rx-...er-change.html
However, note, if you have a FWD RX300, then
For the U140E transmission (FWD)
Dry fill: 8.25 liters (8.72 US quarts, 7.26 Imp. qts)
Drain and refill: 3.5 liters (3.7 US qts, 3.1 Imp. qts)
and for the AWD,
For the U140F transmission (AWD)
Dry fill: 9.15 liters (9.67 US qts, 8.05 Imp. qts)
Drain and refill: 4.1 liters (4.3 US qts, 3.6 Imp qts)
and for the AWD,
Super Moderator
The only fluids compatible (and superior to the OEM Toyota Type-IV) at O'Reillys are:
Mobil 1 ATF
Royal Purple Max ATF
As far as the filter,
http://www.oreillyauto.com/site/c/de...3230&ppt=C0023
Mobil 1 ATF
