Oil Leakage Problem
Hello there,
I own a RX 330 with 40,000 miles, 2002 model.
There is a oil leakage by the cylinder. Either the cylinder hat or the ceiling.
Do you think this is a common problem?
I'm wondering if this is a problem with the gasket.
If so, does anyone know how much it would cost?
Thanks,
Dave
Thanks,
Dave
Hello there,
Thanks,
Dave
Thanks,
Dave
Super Moderator
Hello there,
Thanks,
Dave
Thanks,
Dave
Are you talking about a 2002 RX300, since the RX330 didn't show up until 2004?
Either way, that's not a common problem with gasket leakage.
I would like to know where it's coming from (the rear of the engine or the front).
I am not sure what you are trying to say other than that your engine is leaking. May car had an oil leak from the rear valve cover. I removed the intake manifolds and the throttle body and replaced the gasket. It is pretty simple, also gives you a good chance to see how well you cams are holding up.
sarah
RX - 1st Gen (1999-2003)
33
03-05-09 12:28 PM
