Not trying to kick a dead horse but, P0171 /1135
Old 11-23-11, 10:34 PM
IndyRX300
IndyRX300's Avatar
Default Not trying to kick a dead horse but, P0171 /1135
I have searched all over and it appears that there is no real consensus on the a definitive answer (here recently anyhow) on what the most common culprit would be for this combo,
The engine light is intermitent. Gas mileage is roughly 18-19mpg (AWD). Idle is rough but steady @ 1000rpm. I am thinking the rough vibration is caused by failing motor or tranny mount. Only issue I have with rpms it at 70-80mph and running 3000rpms . Yikes if ya ask me. I have athread about that and getting help but could a bad connection on the MAF cause such high rpms at higher speeds or the combination of the codes for that matter?
Happy Thanksgiving guys and I appriciate your help.
Old 11-24-11, 06:13 AM
hypervish
hypervish's Avatar
Running 3000 rpm at 75 mph is NORMAL! Don't worry about it!
Old 11-24-11, 06:41 AM
IndyRX300
IndyRX300's Avatar
LOL Hyper, You told me a while back that it was high. Not trying to call you out at all bro. As for the codes, I am going to clean MAF again, Clean the contacts and go from there.
Old 11-24-11, 06:43 AM
hypervish
hypervish's Avatar
Find the post. I'm pretty sure I didn't. I run 3200 rpm at 80mph.
EDIT: found it myself: https://www.clublexus.com/forums/6661498-post3.html
You said 4k rpms at 75mph... So obviously I would say that's high. Because 4k is high! LOL
In the post after your's I explain that I get 3200-3400 rpms at 80.
Old 11-24-11, 06:49 AM
IndyRX300
IndyRX300's Avatar
You said 4k rpms... So obviously I would say that's high. Because 4k is high! LOL
My complete and sincere apologies. I must have been.... Nevermind.
Lots of crap running thru my mind. I have enough check engine lights between my two vehicles that I could probably make a christmas display. Once again. I apologize.
Old 11-24-11, 06:50 AM
hypervish
hypervish's Avatar
Hahah. No worries!
For the P1135 you need to replace the Bank 1 Sensor 1 (this is behind the engine block). I would ignore the P0171 because it usually pops up with the A/F sensor.
Old 11-24-11, 06:54 AM
IndyRX300
IndyRX300's Avatar
Yes sir. FYI autoparts123.com are having a 20% off special. If you are a first time user I believe it is also an additional 10% off. I know they carry OEM parts. They are just hit and miss. I am not affiliated with them. just thought I would share the love.
Once again Hyper, You're the chit and I am a total Jack@ss
Old 11-24-11, 06:59 AM
hypervish
hypervish's Avatar
Hhaah, don't worry about it, it's all good!
Just make sure it's a Denso sensor.
I'll check out the website, I do need a new air filter and a cabin air filter. So might as well buy from there.
BTW: Happy Thanksgiving!
Old 11-24-11, 07:34 AM
IndyRX300
IndyRX300's Avatar
Oh hell where are my manners. Happy Thanksgiving to all of you guys and gals on here,
Old 11-24-11, 07:57 AM
Vroomin350
Vroomin350's Avatar
happy thanksgiving guys, I have a p0171 and two other codes I am trying to deal with, any advice?
Old 11-24-11, 10:40 AM
IndyRX300
IndyRX300's Avatar
What are the other codes? P0171 is more than likely an O2 sensor.
Happy Thanksgiving to you too!
Old 11-24-11, 10:49 AM
Vroomin350
Vroomin350's Avatar
Thanks,
I will be scanning it tomorrow again to pull up the exact codes but I do remember it saying rich bank1 & 2.
Old 11-30-11, 04:26 PM
Vroomin350
Vroomin350's Avatar
ok guys here it is.... those are the codes that I keep clearing and keep coming back in every 100 miles or so.
any ideas? I already cleaned the MAF sensor and nothing.
Old 11-30-11, 04:28 PM
Vroomin350
Vroomin350's Avatar
wow just realized it doesnt even throw a p0171
sorry about that folks.
Old 12-01-11, 06:41 AM
Lexmex
Super Moderator
Lexmex's Avatar
P0101, I'd take another look at the the MAF and make sure the diode and the inner wires are entirely clean. That's not a common code. Also look for any kind of leak beneath the MAF (o-ring). The MAF itself could be bad despite cleaning (it's happened to me before).
The other 2 codes are likely related to the P0101 occurring, because if it can't meter the air right...then the air/fuel ratio is off.
Quick Reply: Not trying to kick a dead horse but, P0171 /1135
