Aftermarket ABS Speed Sensors
After reaching about 160,000 miles, I am having issues with the speed sensors. The one on the left rear was replaced along with the driveshaft (to replace a cracked sensor ring that was integrated with the shaft). That was an expensive repair as the sensor itself was obtained from Lexus and cost over $400.
Now the right rear needs to be replaced and I am seeing sensors online for as little as $150. Has anyone had experience using these aftermarket sensors?? I don't want to buy one and have it not work.
2002 RX300 AWD 188,500 miles.
Go here: create a login with Club Lexus on their site, you will get a discount...
http://lexus.sewellparts.com/oem-cat...X300-2001.html
with our discount it will be either $163 or $203 depending on AWD or FWD
Thanks for the reply. The link you provided takes me to a parts list for a 2001 RX. Mine is a 2002. Do we know if the parts are the same? Also, is the price listed before the discount is applied??
Thanks for your help!!
You can call them or email them too. [email contact can be slow .. based on their volume of work .. but phone gets you quicker access]
When it comes to sensor (transponders), I tend to stay with OEM.
Salim
you CAN go to that site and punch in your vehicle, i would think those years have same sensor. the important thing is the AWD or FWD....apparently the sensor wiring must be a different length for the two.
fdibugnara
05-05-17 07:53 PM
