Transmission changes- 2001+
Ive been reading up on the somewhat common transmission issues that plague the 99-00 models. Were there any design changes in the 01+ models that make the trans more robust? The reports of failed transmission in these years appear to be much more infrequent.-
The planetary gear set was upgraded, and I believe the number of teeth has increased to 5. There are pictures floating around somewhere of the part that fails.
You have to remember people don't come online to talk about great their transmission is, so the number of complaints you see are just that. There are so many other people that have no problems.
Whenever I look at when and how the transmission failed. It usually fails before 100k miles. After 100,000 miles, not many people have had transmissions fail. So, if your past 100k miles your probably safe from failure (unless of course you abuse it). Some people might not change the transmission oil as frequently as they should, other's might change it at every 15k miles but use the wrong fluid which would also ruin the transmission. Another transmission killer, is when you don't come to a complete stop when switching from "P" to "D" or "R" to "D", etc. And, of course the leading transmission failure cause is HEAT, which applies to all transmissions of all cars.
Super Moderator
This is not as a big an issue with the RX300, but sometimes in the past there was maybe something that used one thing one year and then the same exact car (but with perhaps nothing more than a new tranny or other slight modification the next year) used a different fluid. Dexron is the one that usually people have to figure out.
Happy New Year to all,
