Battery
Fortunately, the RX is not that tough to crank. The original equipment Panasonic battery that came with the RX300 was probably superior, but I don't think those are readily available in the U.S. The U.S.-made Toyota/Lexus batteries are probably no better than the Costco ones and cost almost twice the price.
I have noticed that my mother's Lexus (year around in south Florida) has had batteries fail more often than my RX (which is not year around in Florida). So, the hot weather may be a major factor in battery life.
Trying not to be negative about this, but I speak as someone who has run quite a few JC batteries and can say from regular testing that they are for the most part a very mediocre battery at best. Problem is, since they've bought a good deal of the competition out, they are the major, and one of the few players left in town. I load test my batteries on a regular basis (every 2-3 months) and charge with a smart charger as necessary and JC batteries, as a rule simply DO NOT hold voltage well, nor do they load test well. My wife's '11 Toyota Camry (which came with a Toyota battery made by JC) has load tested well for it's year + of service but with it showing full charge when we left for 3 weeks over Christmas and New years, upon return a load test showed barely 12.2 V., a 50% charge. There was no drain except for normal parasitic drain from keep-alive components, not enough to hardly show a drop. My experience has always been this very thing with JC Batteries, They may start the car fine, but a load test tells the true story, and it's not a pretty one. Remember, the battery, for a large part only starts the car, from then on the alternator supplies the juice to run things and a jumper battery will start it with sometimes a 1/4 of the cranking amps of you car battery, so the fact that the battery starts the car when you turn the key is a POOR guage of the actual health of the battery. I wish we had the day back when you actually had the choice of batteries that, by load test, showed they actually passed their health check with flying colors rather than the "turn of the key check" which says it started the car, it must be fine. Alas, I'm afraid, for the most part, current marketing flim-flamery has ended that for good.
Optima used to have a great reputation pre JC buyout. Now they seem to be worse than average.
What brand(s) would you recommend? It seems like almost everything is made by them now.
To answer your question- recommendation? The only one I know of currently that holds consistent high standards of quality in build is Odysey (they make the Sears Platinum) but they are expensive enough that I probably wouldn't even recommend it for the average driver. The sadest day for me was when GNB sold to Exide and the GNB battery (they built for an absolute ton of names including Motorcraft but never retailed under their own name) went from being one of the best batteris ever built to another piece of c*#p built by Exide, just in the same plant.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
My retirement job as security on remote desert powerline construction sites means that I absolutely must have strong battery power, no matter what. I just replaced the one in my RX 300 with top of the line Sears Diehard. I also carry one of those battery jumper boxes for emergencies. Battery rundown due to long use of the radio was not an issue in my Jeep Cherokee, but the RX seems to have a higher drain rate, I suspect due to maybe more speakers or the CD changer being online even when not in use.
How many of you remember when Sears sold a battery that had a sepereate section in it that had a small booster battery (so to speak) that would keep you out of trouble if your battery was run down in the toolies. You simply turned a switch on the battery and it connected that section with the normal battery secrtion and presto, you were on your way! It must not have sold well because it wasn't sold by them for very long and it disappeared. You can do the same thing with the battery from a booster, which is very small. It can be mounted under the hood (taking VERY little room, can be connected into the charging system by an ignition triggered heavy duty relay or constant duty solenoid). If you are using a heavy enough solenoid, you simply turn the key on and start it because it is hooked back into the electrical system to act as a jumper automatically. If you have left the key on to listen to the stereo, it would need a simple toggle switch to cut it OUT of the system when the key was on to keep it from being run down with the chassis battery. If I was used to being 20 mi. off-road alone and doing this, that's definitely what I would hook up. It's a "get out of the mess I got myself into free" card.
