rx 300 code p1130
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I have a 2000 Lexus RX 300I have a code P1130 and I changed the bank 1 sensor 1, reset the engine light drove 4 miles and the light came back on. Any clues
Bank one sensor one is actually located between engine and firewall on passenger side about even with back or front pass tire.
be sure the connector is connected all the way.
If all those check out make sure new sensor is from toyota or made by denso. i have reqd about alot of issues using other brands one of those being the code. part number for denso is 234-9009 go to amazon.com they have it cheap. at your local parts store will run you a nice chunk of change
