Cabin Filter location RX300 with CD changer
Old 01-12-12, 11:10 AM
Xtom73G
Xtom73G's Avatar
Default Cabin Filter location RX300 with CD changer
My Owner's Manual does not show how to replace the cabin filter when you have the CD changer. Where is the filter located, and how to replace it?
Old 01-12-12, 12:17 PM
amblyn
amblyn's Avatar
if you open glove box and look back above back of box theres a rectangle cover pull it off and theres the air filter pull it out pop new one in and put cover back on cover can be tricky put bottom in first and pop top of it in not too hard
Old 01-12-12, 04:10 PM
bob2200
bob2200's Avatar
The CD changer is not an issue. You slip out the top-back piece of the glove box and you have access to the filter cover door. Pull that out with your fingers or some pliers and you see the filter.
Old 01-12-12, 09:34 PM
orion603
orion603's Avatar
http://www.carcarekiosk.com/video/20..._cabin/replace
Old 01-13-12, 03:35 AM
toms73nova
toms73nova's Avatar
Nice to see how this is done, but they guy states "rember, the air you engine needs to run goes though this" when he is talking about how dirty it is.
This got me rolling on the ground!! Talk about not having a clue...
Old 01-13-12, 09:47 AM
Xtom73G
Xtom73G's Avatar
Thanks, everyone! I will get to this task asap, and the next one will be my wife's ES300.
Old 01-13-12, 03:48 PM
bob2200
bob2200's Avatar
I have experience with my mother's ES300. You empty the glove box and unscrew the slide to lower it. A little more difficult than the RX300, but still not too bad.
Old 01-13-12, 11:56 PM
NyCrAzY
NyCrAzY's Avatar
Read on the car care kiosk website that the cabin air filter has an impact on gas mileage??
Planning to change mine next week (its so disgusting and dirty!!)
easy replacement to do.
Old 04-06-12, 09:29 AM
jijotomy
jijotomy's Avatar
Smile Not so fast...
That part of the video was shared from the engine's air filter inspection tutorial. True, an overlook from the web admin's part but is nothing about 'not having a clue'. BTW, I found carecarekiosk dot com a very useful site.
Old 04-07-12, 08:40 PM
2002RX300
2002RX300's Avatar
Wow, I have to clean mine every month. Debris gets in there all the time, I just rinse it out let dry and spray some air freshener on it then reinstall.
Old 04-08-12, 05:11 AM
hypervish
hypervish's Avatar
I suggest replacing the filter rather than cleaning it. You only remove the visible debris, but there are many more particles stuck in the filter hindering air flow, and lowering the efficiency of the HVAC system.
Old 04-09-12, 11:28 AM
JERKRICE
JERKRICE's Avatar
TO ALL: i need some help here,rx300 awd (1) the palce where my cabin air filter goes i have being hearing some scrathing noise...like some animal trying to get out i have remove the fliter and check but could not see anything....i wonder if it is a snake in there...lol or motor /parts going bad
(2) i am on doing a transmission drain and filled, should i replace the filter too? i bought the car the 175000 miles on it.now 183000 miles. and wat to use and clean the transmission oil pan after removing?
(3) AS ANYONE USE THE AUTO-RX TREATMENT ? AND DOES IF AFFECT THE RING/VAVLES ETC ...MORE NOISE ANY INFO ACCEPTED.
THANKS
CURRY/JERKRICE
Old 04-09-12, 06:39 PM
takaiguchi
takaiguchi's Avatar
Just changed out my cabin filter for the first time since having the car. Holy cow it was gross.
Old 04-10-12, 06:14 AM
MilesE
MilesE's Avatar
THANKS
CURRY/JERKRICE
The "mouse in the glove box" noise is a well documented problem on these boards. The quick explanation is that it is probably one of your servo's going bad. I'm having the same problem and plan on replacing one this week. Do a search on here for servo's as there's a lot of information on how to do this repair.
Old 04-10-12, 06:28 AM
hypervish
hypervish's Avatar
THANKS
CURRY/JERKRICE
(1) The noise is probably from a servo motor in the dashboard for the HVAC. Do a search on here and you will find out how to get to them.
(2) These transmissions from the factory have screens instead of filters. Meaning you can just clean it and put it back. That is unless someone has already replaced the filter with a paper filter. Since you can no longer buy a screen filter. You can use brake cleaner to clean the transmission pan. Remember to use a Toyota Type-IV transmission ATF.
(3) I haven't used Auto-RX personally so I can't really comment on that.
aznkorboi
RX - 4th Gen (2016-2022)
31
11-13-18 03:02 PM
ohnow
02-18-13 05:41 PM
frotiss
IS F (2008-2014)
11-22-11 05:49 PM
Larry99
08-23-03 06:16 PM
subal
08-20-02 03:20 PM
Quick Reply: Cabin Filter location RX300 with CD changer
