Help with 1999 RX300 189,000 miles intermittent miss cylinders 3 and 5
The vehicle was running fine. The wife stopped and got gas. She left the station the engine light
began flashing. At idle the vehicle does not seem to miss and the light goes away. As you accelerate to 20 mph the light begins flashing.
Took it to a locate garage i trust to see if they could diagnos the problem. They spent 4 hours on it coming up empty. All they could tell me is the coils, plugs, injectors, vacume pressure, and compression checked out good. The compression could not be checked at time of miss due to it being intermittant. The V.V.T. actuator was unplugged and the problem persisted.
They recommended taking it to a lexus dealer who has the parts to diagnose the problem.
Any one had a similar problem or ideas where to go from here. Taking one last shot before going to the dealer.
If your sensor gives bad reading causing to rich or to lean of a mixture it will cause a misfire. Hope i helped good luck.
I am finding alot of information on the forum concerning OCV or Camshaft Control Valve problems causing misfires similar to mine. Found this thread http://us.lexusownersclub.com/forums...howtopic=44742 on the topic.
Anyone had any experience with this problem.
I would think it was the gas causing the problem but this misfire is only on 3 and 5.
I not sure how he tested the injector but he said it was good. He said he spent 4 hours trying to diagnos the problem and did not charge me for his time.
Thanks for the reply.
Update my vehicle quit running or starting all together and was producing codes p0300 p0303
p0305. I cleaned the IACV valve and throttle plate with "Seafoam" they were very dirty and the IACV appeared to be stuck. The vlave **** would turn but require quit a bit of force. Once cleaned the **** moved with little force.
I started the vehicle with starter spray it would run for a few seconds and die. After several attempts and thinking over night I changes the fuel pump and filter out. The car starts fine now but idles too high. Anyone had a similar problem after cleaning the IACV with "Seafoam" or is the IACV shot all together. I cleaned it with the valve still attached to the throttle body.
Thanks
Thanks
ProfessorP
18
04-08-09 06:29 AM
