Question on antenna motor issue
I dont have a solution, but have few questions which might lead to the solution (I hope).
So what determines the limit of motor run. The video does not show that. In a bench test, I would expect the motor to run and run. The limiter would also throw the switch to swap +12v and 0.
The problem could be in the limiter ... acting too quickly.
Note: I have not opened up the antenna motor, so my knowledge is fairly limited.
Salim
Salim
Salim
Salim
As i mentioned only about once or twice in 15-20 runs it would continue to run in same direction i.e. it would allow to finish the antenna UP or antenna down movements fully.
For all the other runs, as also seen in the video, it would only run for couple of seconds, which is not enough to finish the antenna movement.
When i started with the antenna fix, initially i thought it would be broken mast that is not allowing the complete movement. But my antenna mast was all good.
Then i thought it needs lubrication, and that also did not help. So finally when i took everything apart and connected the power i realized that the actual motor itself is not making the complete movement.
My knowledge of Electrical parts is limited and thought to check on the forum if motor is something that can be repaired or ordered separately, as the other parts are just fine.
If the OEM unit is priced high, I would look at the after-market stuff instead of trying to repair the motor alone. The non-oem would not make any difference in how your vehicle will operate. So what if it lasts 3 years and a breakdown would not leave you stranded. Your labor is free ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
And it may not be the motor that is bad.
Salim
Salim
