trouble starting
Old 03-24-12 | 09:24 PM
savernus's Avatar
savernus
Default trouble starting
Hi; my '00 rx300 has 211k miles. I notice when i park on an incline i have trouble starting, seems like the engine isnt getting enough gas to turn over. If it does start, i have to keep the rpm up or it quits. But after a few miles theres no issue, and there arent any issues starting after parked on a flat surface (eg driveway). I took to local garage but the problem didnt present again so no action was taken. Any suggestions?
Old 03-24-12 | 10:44 PM
salimshah's Avatar
salimshah
Does it run at start, if you keep the gas pedal depressed just a bit? If the answer is YES then search on IACV.
Tell us a bit about cold start and warm start conditions?
Check your air-filter too. At about 220k miles you will need a new set of plugs (assuming the first set was changed at 110k miles)
Try keeping your gas tank more than 1/2 full.
Salim
Old 03-26-12 | 07:45 PM
sktn77a's Avatar
sktn77a
Does it start and then stall? If so, look at the throttle position sensor and the MAF, too.
Old 03-26-12 | 08:47 PM
GS4_Fiend's Avatar
GS4_Fiend
If it only happens when parked on an inclined than the fuel tank is tilted and the fuel pump is not getting enough gasoline through. Just a thought.
MJA1951
04-18-18 06:14 PM
kyle0k
10-07-13 11:48 AM
klobb92
Performance & Maintenance
16
03-26-13 05:18 PM
Leolo007
05-28-12 08:22 AM
bzubke1
10-11-08 07:19 AM
Quick Reply: trouble starting
