I want to get to the bottom of this ... why is my gas mileage BAD?!
#31
These might help: https://www.clublexus.com/forums/rx-...t-low-mpg.html
Reviews:http://www.amazon.com/Denso-234-9009...pr_product_top
Also ... I may just come to the conclusion that its because of my short trips everyday but I have to ask you guys this though ...
1.) How many miles y'all get per 5 gallons? I only get to 58-63 miles before the low gas light triggers (87 octane gas)
2.) What RPM should my car be in when driving between 30-45mph? Mine is usually around 2000.
Just askimg out of curiousity.
Thanks,
Kind regards.
#33
I think the two mile trip is really killing your mpg. The car runs' real rich and wastes a lot of gas when driving very short distances because it tries to warm up faster. I honestly think this is why your MPG is really bad, nothing mechanical is wrong with your car ( i don't think...lol).
Just two miles to work? With these gas prices I would ride a bike!
#34
Took a trip to Dulles Airport two days ago which is 25mins away from my house consisting 55mph speed limit roads.
& obtained 17.7 mpg! And went back down to 16.4mpg the past day driving to work ... since I assume the car is running rich while driving those 2 miles to work?
Planning to go to NYC soon so hopefully I can obtain 23-26mpg highway readings that Ive seen other members get
#35
#37
Absent any obvious issues with the car, I believe you should be getting low 20's on the highway. Looking back on everything you have done, I still am not sure what else you could possibly do to address this...
#38
I still think you have a failed, or failing, O2 sensor which has merely yet to trip an emissions error.
I've had it happen, before. Took a while to figure out, too, but when the O2 sensor dies, the engine defaults to max fuel, i.e. full rich, all the time.
#39
18mpg (or 17.7) still is just *not good* imho for highway mileage even with these cars. I'm assuming that there was not a lot of stop and go (were you on the Dulles Toll Road?) My best mileage comes when I set the cruise and sit back and let the car do the driving, so to speak.
Mileage now went down to 15.7 now from a quick trip to McDonalds, lol.
#40
Just started the car (12:05am) and my RX300 triggered a CEL.
Will report back later in the morning or afternoon when I go to my local Advanced Auto Parts to get the code read.
#44
https://www.clublexus.com/forums/rx-...ml#post6847214
Check that thread..someone had a similar problem.. .but with other codes... ive dealt with a P0446 before, but never the P0450 but it appears others on the forum have.... there are a few models that use our engine..so alternatively you can search for the 1MZFE P0450 as well for more results that may be helpful..
Cheers
Cheers
#45
Thanks for the link, bud. Only thing I could of thinked of was my gas cap ... which is already tight.
I just cleared the code and see how it goes from there on.
What exactly is a pending code? How can I check if I have any of those?
