Bluetooth Interface feedback: BT35-TOY
https://www.clublexus.com/forums/rx-...-f-s-j-ca.html
Partywave was able to do it. I believe his installer used an additional cable though.
In the alternative, is there a stand alone blue tooth system; something with its own audio source that doesn't run through the radio (akin to the old hard wired phones) that anyone would recommend?
I use an FM modulator (iSimple IS77), and I have that connected into a Kanex AirBlue which is basically a portable bluetooth music receiver.
Thanks!
Thanks for your insightful information about this versatile product that seems to work well with our RX300's. I'm curious about your above statement. Is the CD changer permanently disabled in favor of the Bluetooth device, or is it only while the Bluetooth is linked to the phone (or other device)? If so, I'm not sure why both would be in use together... perhaps I'm missing something because I have not used a similar device before.
Thanks!
Thanks!
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
I just purchased a BT35-Toy with a CAS-LEX cable for my 2002 RX300 with Nav Radio. I removed the CD changer (required) and I'm ready to finish this 30 minute installation and I realized the cable will not connect. Looks like I need the same connection on both ends.So what am I missing? Does anyone have pics of this install?
Thanks,
Z
Thanks,
Z
I will have to respectfully disagree. I installed this in a first gen (2000) RX300 and you installed this in a 2008 RX350 - two very different vehicles. I also emailed the manufacturer and they confirmed that for my vehicle (again a 2000 RX300 with an external CD changer), you have to disconnect the cd changer.
rkristof
06-12-18 03:23 PM
Rotcod
01-04-18 06:29 PM
ntscott
RX - 1st Gen (1999-2003)
11-20-14 12:54 PM
z0lt3c
09-20-12 09:55 AM
