DIY Radio Antenna Mast
#61
Any suggestions on this broken part?
Yes!
After removing the crown nut and letting the motor over-run to release the nylon the mast should fall off. Since it is not coming out, either you are not pulling hard enough or something is binding (crooked mast segment, nylon cable etc. Snips will enable you to set if free to then disassemble the motor assembly.
Salim
Salim
This was much easier than I thought. The problem I have was right at the beginning. My 2003 RX300 with 250,000 miles has seen a lot of weather. The bezel (black plastic trim piece) where the nut you loosen with needle nose pliers is cracked beyond repair. I already have my replacement antenna, but does anyone know where I could get a replacement? Thanks!
#62
Otherwise, found this site...
b2884987
12-14-16 02:36 PM
1995LS400
12-04-07 06:43 AM
