Changed my plugs, got 2 codes
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
After putting in new plugs, I drove for about 6-8 miles, and then get a CEL.
Had the codes pulled and I have P1130 & P1150.
Any thoughts or things to look for?
I did a search, just wondering if everyone with those codes ended up changing out both O2 sensors?...or did they find any other problems?
You'd probably have a better chance of winning the lottery than both A/F sensors going out at the same time just after you changed the plugs. Did you use anything in the intake BEFORE you changed the plugs? Any type of cleaner or anything AT ALL on the plugs or ingested into the engine? A lot of people don't realize that you can contaminate the sensors with a number of things that can potentionally pass over the sensors and polute (read destroy) them. I would suggest cancelling out the DTC's and see if they come back. If you do this a couple of times and they keepcoming back, I would give consideration to the things I've said. New sensors MAY cure the problem, but I still say WAAAAY too much of a coincidence for them to have failed simultaneously without any outside influence.
Either of those would make more sense to have both sensors throwing AF codes at the same time.
I am going to pull the plastic engine cover and check to make sure I did not 'knock off a vacuum line' or anything else. The Autozone guy that did the scan also stated that a crushed/crimped fuel return line has been the cause of those codes on other vehicles....but I believe we have hard pipe fuel lines and I'm certain I would have known if I damaged something like that.
Also going to dump in a can of injector cleaner, as that seemed to work for another forum member.
defo, when you check to hoses for a vacuum leak, make sure you connected the one behind air filter box extending down to a metal tube between the box and firewall. It extends out of the intake around or below the MAF. I left mine off once and got some codes. That little hose is easy to overlook.
llllllllll
IS - 1st Gen (2001-2005)
03-25-09 12:07 PM
