Trac off indicator and CEL on, P0125!
Old 07-16-12, 07:45 PM
1nablxsonr
1nablxsonr's Avatar
Default Trac off indicator and CEL on, P0125!
Hi all. Im trying to get some ideas/suggestions on how to resolve p0125 code. closed loop insufficient cooling? I recently did coolant change, using all recommended steps additives and fluids. Took off negative cable of battery for a min. to reset. After all that, lights still on.
Old 07-16-12, 09:04 PM
GS4_Fiend
GS4_Fiend's Avatar
Make sure you dont have low level of coolant and you dont have air in your cooling system. Also, have someone with a scanner that can read live data, check what is the ECT reading when the car is fully warmed up.
Old 07-16-12, 10:45 PM
1nablxsonr
1nablxsonr's Avatar
Okay,will do. Would you happen to know any values for ECT?, or is it open/closed? I'll stop by neighborhood ORiely's 2morrow. Thanks!
Old 07-17-12, 08:33 PM
GS4_Fiend
GS4_Fiend's Avatar
At normal operating temp, ECT readings should be around 190-200. Just a guessitmate but it gives u an idea.
chopstick8
32
09-26-20 01:50 PM
ne0tekk
05-03-18 05:49 AM
AlDavison
12-29-17 12:00 PM
jiggahwh0
07-23-12 06:21 AM
Higgo
10-30-11 08:19 AM
Quick Reply: Trac off indicator and CEL on, P0125!
