HID lights
I just recieved the lights and put them on and they dont work? i checked all the wires and all checked good but then i saw that they wont work if the car has day light running lights and if the lights are automatic?? help
Are you just changing the low beam bulbs to hid bulb + ballast or doing a more extensive change?
Headlamp houses high-beam and low-beam.
DRL uses high-beam bulb with each bulb getting about 6v instead of 12v.
Usually, the high beam should not be messed with when installing the HID,
HID can only operate on 12v -> ballast -> high voltage -> hid-bulb
You should check the instructions from the manufacturer of the HID setup you.
12v going to ballast should be independent of auto/manual head-lamp-on. (it should not matter).
Lastly, try going to the site of the HID manufacturer as they should provide you with the needed information.
Salim
Salim
Take a bit of time to explain your problem ,, keep in mind we are not there with you and your text here needs to convey all the information.
Salim
Sorry....on the ballast there 3 plugs and the sheet says 2 things if the HID lights dont turn on reverse this plug showing the the last plug and it says you need to disable the daytime running lights drl syestems do not work with hids
scdroptop
03-25-09 07:53 PM
