Dealer claims I need a new power steering pump, but...
Went to the dealer for an oil change as I got a special emailed to me. Sitting there eating as many free treats I can stuff down when the service adviser, a decent guy, tells me the mechanic indicates I have a rear main seal leak and he will quote me a price but it's costly as the engine needs to be taken apart. When the oil change is done, the adviser indicates the mechanic now states it's a power steering pump leak not a rear main seal leak. I noted I have no spotting in my garage; the adviser says the leak may not reach the ground. He quotes me $920 for replacement, and I would have an indy do it. I checked the reservoir and compared it to the manual - it looks OK, perhaps a touch low. Important to note the power steering is working fine.
My question - is it ok to blow this off until my next oil change in four months and ask an indy for a separate opinion or presuming there is a leak, can this cause more problems by ignoring it?
Thanks in advance for any advice.
Thanks guys. That's the answer I was looking for. One other thing crossed my mind so I checked and it looks like Lucas has a well reviewed product for slow leaks. Whatcha think?
I wouldn't rush and put sealant in the pump. Let it be, monitor the fluid level and only act when you see an actual leak. The level will go up and down depending on temperature, and you may very well never even need a top off. A $900 job on a whim, sounds like fishing for a person willing to pay for nitrogen in their tires. Save your cash.
yep best thing is to take a turkey baster and suck out most of the fluid in resevoir and add fresh afterwards...might dulute debris in the fluid, and be just fine.
Actually, not having a FSM - how are you supposed to replace the PSF by the book? Like others, take the reservoir discharge hose off, put in the drain bottle and add fluid with the engine running?
