Timing idler was supposed to be all
Well, I think I need a bit more playing with my RX300.
When I bought it two weeks ago I knew I hear the squeal of the timing belt idler. I thought, oh well, pull the upper cover, replace the $20 idler. Turns out - correct me if I'm wrong - the upper cover won't come off until the lower cover is removed because one bolt is covered by the lower. And of course the lower won't come off until the balancer is removed.
Well, at that point I will have the entire timing path opened up, might as well replace the belt, which I was told is 40k miles old but who really knows. And once there, might as well replace the water pump, I bet nobody has ever done this on this poor Lex in its 167,000 miles.
And of course I need now to make a tool to hold the pulley when tightening the bolt.
<whine> Everything is a project, isn't it? Seems like all I do now is service timing belts. This would be the fourth one this year I think
</whine>
Yea, I think you got it right. But i would put on new OE accessory drive belts first and see if it goes away (unless of course you want to do the timing belt right now). The accessory belts make all kinds of dried up bearing sounds when they are slipping and only an OE belt seems to do the trick (they are cheaper than aftermarket anyway).
Unfortunately, I am positive it is not the external belt. In fact it looks completely new. I can hear the squeal coming out from under the timing cover but would not bet if it is the top or bottom idler. The thing is, I don't want to wait for it to seize because that would nearly immediately cause the timing belt to overheat and break, with all the proper consequences.
I was intending to call the dealer for the timing kit, actually. While aftermarket idlers are IMO ok, the last time I bought an aftermarket timing belt it looked so cheesy, I couldn't install it (Honda). The one for my Kia (Dayco) was great, nice and shiny, with great looking armor fibers. The one for the Honda looked like it was home made. It is also possible that the quality simply has gone down with the recession.
Nonetheless, I will be calling around. Last time I did the timing belt for my RAV-4 and decided to replace the front seals, aftermarket cam seals would not fit. Tried 8 of them, from $5 to $18 and none fit - too small, too large, too soft. Finally called the dealer and got an OEM for $3.45 and of course it fit perfectly. It was an eye opener, I have never before had a dealer part cheaper than Advance Auto. So I am not at all opposed to OEM, if my antifreeze post made people think so
Well, the friendly dealer wants $489 just in parts. I think I will pass.
BTW, they told me that I can go with either "the old-style red antifreeze", or with new long life. I am guessing, Toyota is doing away with red antifreeze.
Looked at a Gates timing kit today at O'Reileys while picking up CV axles and AT filter for RAV-4. The belt is made in the USA, appears to be high quality and has the Toyota-like timing marks. Both idlers are made in Japan. I don't think I have a problem with these parts, cost $90.
If you buy from Sewell, you can get the whole 90k service kit for only $113, that price is with the CL discount. That includes: (I'm copying this part from the website)
-Oil Filter and Drain Plug Gasket
-Air Filter
-In-Cabin Microfilter
-Brake Fluid
-Timing Belt
-Coolant
I'd say that's a great deal!
Also, please, please stick with OEM parts. Toyota knows what they are doing. Stay away from aftermarket. But, in the end it's your money, so buy whatever you please.
-Air Filter
-Brake Fluid
-Timing Belt
-Coolant
Thanks for the hint to Sewell, hypervish. All the parts I need are $100 less there than at my local dealer.
To 58, I take no offence since even your handle means "Heater Control Circuit High", so I guess excess heat is explainable.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
