handle lubrication question
have a stricky handle of rear hatch of 99 300rx. this means automatic door locks, by key fob, do not always work [ie handle does return fully to neutral position]. any advice???
Early model's of RX had a defect in the hatch release. You may want to verify with the dealer. It very well could be an age factor too.
Salim
Salim
The release can be stuck as if the lock has been set.
Salim
Salim
I had that problem in the initial years and the dealer took care of it.
Word of caution .. out symptoms are the same, but the root cause can be different .. wear/adjustment etc.
Salim
Salim
