help me check engine and vsc light on (P0300)
I have the check engine and vsc light on, and code P0300 (get the code from autozone)
this is first happened after oil change about 200 mile.
I read forum and learn it could be the hose behind air filter was disconnected, However I cannot find the hose, so I just ignore it for two month drive with this code on, now I have time thinking about fix it, with this code, if it could still be just the hose? where I can find the hose?
thanks
thanks
if this is not the hose, then what I should to do with it? thank you very much
