Vacuum Switching Valve leaking
hi,
I have a 2000 RX300 & have recently noticed low idle like 300-500 rpm's. It will stall from time to time as well. I finally found what I believe is the problem. The vacuum switching valve on the drivers side appears to be leaking a significant amount of air. Is this infact the issue I am having?
If so it appears to be a simple repair am I correct? Any input is appreciated.
Thanks
Thanks
Not to sound harsh, but you have found the problem. Are you guys having a problem making a fix? Or are you looking for a confirmation that a vacuum leak can cause idle issues?
Salim
Salim
My question is vaccum switching valve near the engine mount in front with clicking noise while holding brake in idle, is that normal? I have the idle vibration problem in D while stopping.
