RX300 Front Passenger Window - switch or motor?
#46
Well! I also need these relays. Any luck?
Is this legit?
https://www.aliexpress.com/item/CR2-...3-383e6a0323fd
Is this legit?
#47
Nothing on my end. Had no luck with aliexpress
Is this legit?
Is this legit?
#48
#50
I got the relay on Saturday and installed it. It was a pain getting the solder off. I had a desoldering wick but it would not "soak" the last amount of the solder up. I ended up pushing on the pins (two at a time) with the soldering iron and prying with a small prying "fork". Took a good hour. After I got the old one out I had to melt the solder and stick an ice-pick like tool through the hole on all seven holes so I could get the pins back through. The video on you tube mentioned a bad desoldering wick and he went and got some better stuff; maybe the stuff I had wasn't too great either. Oh, I had one of those devices to suck the solder off too and it worked okay on one pin; not so well on the rest. It might be my poor skills with soldering or my poor quality kit.
If anyone runs onto a cheaper option I wouldn't mind getting 3 more.
Oh and forgot to say the window worked (for now)!
#51
Seldering and desoldering is a skill which you develop with time and having good equipment helps a lot. Right soldering iron (wattage and temp control), proper tip, and desoldering wick + suction pump can make the whole job easy. Glad it worked out for you and the traces on the board did not get lifted.
Salim
Salim
#52
When you say traces do you mean the copper conductors running through the board? I had a good selection of tips. Soldering was literally 100 times easier than desoldering; almost looked as good as it was before I touched it. Maybe the flux on the desoldering wick had dried up; it seemed that it just didn't want to "suck" the solder onto the wick. For my 2nd solder job I would rather not work on a project that is a possible $800.00 boo boo. I am going to buy some 0.6 mm solder and try my hand at fixing the unlock button on the key fob.
#53
2000 RX300 - Any thoughts on this?? Window initially would need to go all the way down before I could return it to the up/closed position. Then, it went down, and will not return up. Same clicking noise from FP switch and MS. Replaced motor. Only goes down. Figured it was the either the MS or the FP switch so I replaced them both. Same result. Called Lexus, suggested I "re-initiate" using the MS by holding the front passenger window toggle down for 3 sec, and then up for 3 secs. Same result of clicking and an no action. I don't believe it's the motor or the switches at this point. Any other thoughts or help is appreciated greatly.
#54
Quick Update - the problem is in the switch on the passenger door. I have tried to re-flow all the solder joints to the connector pins on the circuit board, but that did not correct the problem. I have found, however, that if I disconnect the passenger side controller, I am able to operate the window from the driver's side master switch, so at least I can raise and lower the window. If I keep the passenger side controller connected, I cannot operate the window from either side. I'm going to give the circuit board one last look and try a few more solder joints before I break down and buy a replacement controller/switch assembly.
#55
My problem was the relay was sticking. I smacked the relay with my finger and the window UP switch worked immediately. So I was sure it was the relay. While I was in there I pulled the white plastic pins out of the Auto mode as I hate that the auto mode is too sensitive.
So now I can tap up and down they never go auto on me.
I got my relays from the USA in 3 days.
I tried mouser and digi-key and they are out of stock since 2010.
The guy at one of them gave me the number to Lakeland Logistics in NJ.
They had about 550 of them on the floor. Only problem is a $50.00 minimum order. So I bought 6. One for each window and 2 extra to sell. My total was $55.00 and I ordered Monday and they arrived Thursday.
I soldered one into the right front door and problem fixed immediately.
You can contact
Steve at Lakeland Logistics, Inc 300 Fifth St • Belvidere, NJ 07823 (P) (908)475-8282
The part number is CR2-12v
If you only want 1 or 2 I have two to sell to recoup some of the $50 minimum. I will sell one or 2 for $15.00 each + postage. Free postage for 2 and you dont have to wait 4-6 weeks for Aliexpress.
PS, there are panasonic parts.
You can contact
#56
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I made an account just so I could reply and thank you all for you help! I had the exact same problem as OP (window would not roll up all the way, switch did weird stuff) and eventually the window just got stuck down. Took out the switch - the thing with the circuit board in it - following the instructions that were linked n this thread. Connected the drivers side board to the passenger wires and got the window rolled up! I've never done any sort of fixing on my car before so I was thrilled that it worked. Easy to do and a must try before you spend $ taking your car somewhere!
#57
"ECG J-045-DS Electric Corded De-Soldering Iron, +420 Degree C Tip Temperature, 45W"
![https://www.amazon.com/ECG-J-045-DS-Electric-Soldering-Temperature/dp/B00068IJSG/ref=sr_1_3?ie=UTF8&qid=1495581462&sr=8-3&keywords=desoldering+iron](https://www.clublexus.com/forums/images/misc/amazon_icon.gif)
Hope that helps.
Regards . . .
steelgtr (08-07-17)
#58
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I may have a similar problem : the rear driver side window stuck with noise when the main switch or door switch was pressed. In the end, I fixed the problem by :
" Close the door loudly while pressing the switch" as I searched.
Then the door switch worked fine since then.
My 0.02
My 0.02
#59
You can contact
You can contact
thx
bob
