Squealing when it starts ?
Old 09-19-12, 01:15 PM
BROKERIN
BROKERIN's Avatar
are there 2 belts on this 2001 RX300 ? If so I am going to check on having them replaced !
Old 09-19-12, 01:23 PM
hypervish
hypervish's Avatar
Yes, two belts.
http://lexus.sewellparts.com/oem-cat...X300-2000.html
Old 09-19-12, 01:43 PM
BROKERIN
BROKERIN's Avatar
Do I need to replace both belts ? and are there two f them ? are they easy to replace ?
Old 09-19-12, 06:28 PM
salimshah
salimshah's Avatar
Received 1,069 Likes on 962 Posts
There is a recommended milage at which they are scheduled to be replaced or when there is a problem.
One belt goes over the main, alternator, A/C compressor and the second is on main and steering pump.
Fairly easy to replace, but getting the right tension needs special tool. There are some ways to estimate, I am not a fan of that. Please search.
First figure out, if there is a problem with the belt(s).
Salim
Old 09-24-12, 12:50 PM
BROKERIN
BROKERIN's Avatar
Got it taken care of the 2 belts as well as the timing belt were all new just about 2 months ago so I went back to the shop that put them on and they graciously TIGHTENED the belts because after a monthe they loosend up from wear. All is good belts are tight no squeal and running like a champ !
cardboy008
GX - 1st Gen (2003-2009)
01-18-17 09:32 AM
King700se
Performance & Maintenance
01-07-16 03:54 PM
kez
07-24-10 06:41 PM
Jinx2006
05-15-07 05:21 PM
kaotiq
24
03-18-05 07:23 AM
Quick Reply: Squealing when it starts ?
