RX300 Air Mode Servo removal made easy
#91
No cold air from passenger side vents
Thank you for guiding me to the other servos. Which one of these may be responsible for there being no cold air coming from the passenger side vents even when the cold air is coming from all other vents? The passenger side vents are blowing warm air. Are the three servos different and if so, where can I look up the correct part number for the servo that I should be replacing?
#92
I am stumped ... first gen does not have independent temp control for driver/passenger.
There must be something else going on ... that may require tracing the duct work.
Salim
Salim
#93
I've seen many others posting the same issue where the 2 passenger side vents are delivering warmer air compared to the 2 vents on the driver side and 2 vents in the middle for the rear seats but I haven't seen a resolution.
Can someone please point me to any documentation where I can find and trace the duct work?
#94
There's not much hope for me if even you are stumped. My passenger is not going to be happy with warm air in this hot California weather.
Just follow the plastic duct work ... it sure can help when the dash is opened up. If I run into a picture of opened up dash I will link it for you.
Salim
#95
I am stuck at loosening the top screw pointed by the RED arrow in the photo. There is less than a finger space between the screw top and the 2 aluminium tubes which are running in parallel with no gap between the 2 tubes.
I need advice about getting this screw off.
Thank you.
Is it safe to try to bend these pipes somewhat to make room for a ratchet or other tool to get in to remove the top screw of the second servo?
#96
I have both servos out and will attempt to service them as described in many fine guides above. While the servos are out, I tried to manually move the damper levers to see if I can get any cold air to the passenger side vents. None worked. That confirms my problem is not with the servos. I'll service them anyway but the mystery still remains, I don't think I've the ability or know how to safely remove the dashboard and then put it back together.
Is the repair manual available online anywhere to trace the path of air ducts?
#97
I replace both servos today and it was a lot easier than I expected. The screw behind the piping were easy using a short small straight screw driver because with that you can turn a Phillips head screw fairly easily. I worked on this yesterday for about an hour and this morning for an hour and all works good now.
After the servos I replace the antenna mast because when I got the car the tail piece was gone. This project was a pain in the ***. The tail on the new mast would not line up with the hole in the base of the mast sleeve so I everything had to come apart. This toke longer than the servos.
#98
I bought the servos that I used from Rock Auto and they showed a third servo. Is there actually a third servo? I think it is supposed to select between outside air and recirculated air. The third servo that they show is labeled as for the recirculating damper. Anyone know anything about this.
#99
Try to look for one near the blower motor once you has removed the glove box.
#101
Thanks everyone who has posted in this section! After 2 years with no heat in my 2002 Lexus RX300, I found and ordered a mix servo from Amazon. My 18 year old daughter, who can do anything once she sees it on you tube, took apart the "guts" after I removed the glove box. She replaced by dead mix servo with the new one and voila, we have heat!!!! Just in time for our cold spell. Thanks again folks!
(she also removed a full size sheet of paper from the blower motor which solved our noise problem.)
I am confused so many Servos
i have two problems
1) loud random clicking noise
2) no heat randomly
if I could figure out two part numbers I would just order two new Servos
#102
#105
RX300 Mode Servo Replacement
I just replaced the Mode Servo in my 2003 RX300. I installed the Dorman 604-917. Tips on the thread were very helpful, especially using hose as a screw starter for the 3rd hidden screw. Problem is the plastic tip on the cam of the servo strikes the cam on the HVAC assembly when going n and out of Defrost vent. It makes a distinct pop when the 2 cams touch. It appears the servo is about 1mm too short. Is this an installation issue or an off spec aftermarket part?
Margate330 (05-29-22)
