Replacing the RX300 Transmission
having the worst luck with this thing, the guys doing the overhaul just called me and they are saying i need a replacement transmission now and the old one cannot be fixed. thats going to be impossible to find is Australia. the transmission is totally broken inside and the lose parts have damaged the housing. totally run out of options now..thanks so much for the advice and help guys.
I wasn't saying not to replace them just saying if they're not bad save your money. When I rebuilt mine I was told numerous times that they were the problem but after I tore it apart they looked brand new
What I try to do is, bring up the issue and let the owner decide which way they should go.
Salim
then the next thing was after i started driving it go's from 2 to 3 fine but over revs when it go's into 4th and shakes alot.. but didn't have any issue when you have been driving for a while.
and then after all that about a month ago, it just halted on the middle of the road, when i stepped on the gas it didn't move at all.. i couldn't even push if off the main road. because it was stuck in gear. the tow truck dragged it off the road non of the wheels rotated.
well i finally found a transmission with only 78000km on it, also replaced the torque converter and the differential. but i seem to have the same problem rising with this transmission still over revs to goto 4th from 3rd.. could there be something wrong with the computer? can this be reset ? any help would do. all i'm left with is to get rid of it.
Super Moderator
i think your correct, i have done about 1000km so far and i think its starting to come good. been driving it alot more lately and it looks to be much smoother when shifting. Thanks for the advice.
vinster29
RX - 1st Gen (1999-2003)
17
04-03-05 01:02 PM
