Random window movement
my pass side rear window has a mind of it's own... If the windows aren't locked it will go down a bit at a time on it's own... Anyone come across the window ghosts?
Disconnect the rear switch or use the lock out from the front and see if the problem goes away.
Salim
Salim
Based on what you state my money is on the rear switch. [You can operate the rear window from the front with the lock-out activated]
Salim
I will disconnect the battery today while im finishing off the backup camera install. i did check and none of my windows will work from the drivers seat master control while locked out... so im not sure if that is normal or an indication of an issue... all window motors work, im wondering if maybe that motor has also gone funky as i sometimes can hear a noise coming from that door while the motor is not in use.... still rather odd..
