Door won't unlock manually or with piggybacked actuator?
Old 12-29-12, 09:48 PM
Momscar
Momscar's Avatar
Default Door won't unlock manually or with piggybacked actuator?
2001 RX 300 - Here is the deal:
Driver door doesn't lock or unlock via remote (all the other doors do) No actuator movement
Driver door doesn't lock or unlock via Power switch (all the others doors do) Yes actuator movement. In other words the red manual button moves but the door doesn't lock or unlock.
Driver door cannot be locked or unlocked manually with the red button.
Manual key insertion is the only way to open drivers door.
I've had a piggybacked actuator working perfectly for 3 years on the drivers door.
Old 12-30-12, 06:45 AM
carguy07
carguy07's Avatar
Sounds like a linkage issue. Probably have to open it up and see what's going on.
Old 12-30-12, 01:31 PM
Momscar
Momscar's Avatar
Default You da man Carguy
You hit it on the head carguy07
I included some pictures of the broken cable end. The cable gets a little more stress due to the piggybacked actuator rod not allowing cable end to swivel as easy as without actuator rod.
That's my theory and i'm sticking to it.
Cable broke right at the swivel end
A look from the backside
Other end of cable that was inside of the yellow plastic case that had to be removed.
Any ideas on where I can get this cable quickly, as car is out of commision without a door latch.
Old 12-30-12, 03:09 PM
Momscar
Momscar's Avatar
So the cable I need operates red button.
The other cable operates the door pull latch.
Which one of the 2 parts below do I need I could not find picture/microfiche ?
CABLE ASSY, FRONT DOOR LOCK REMOTE CONTROL, LH
69710-48010 1998.01- MCU1# 1
$15.12
$11.72
CABLE ASSY, FRONT DOOR INSIDE LOCKING LH
69750-48010 1998.01- MCU1# 1
$15.12
$11.72
Close up of break.
Old 12-30-12, 05:52 PM
carguy07
carguy07's Avatar
I would be tempted to rig it by crimping an electrical connector to the cable.
Old 12-30-12, 05:56 PM
carguy07
carguy07's Avatar
See if this helps: http://www.trademotion.com/parts/200...agramCallOut=5
Old 12-30-12, 06:32 PM
Momscar
Momscar's Avatar
I'll call them tomorrow . If they have the part, there less then a half hour away.
Fingers crossed.
Monday:
Damm, they didn't have it. Said it will be 2 or 3 days to special order. Guess I should be glad, after some research some models don't sell just the cable. You have to buy the whole assy.
Might have to put it back together, I have a string holding the door shut.
Old 12-31-12, 01:20 PM
vr4/sc400
vr4/sc400's Avatar
I don't have an extra entire cable, but I do have the end you broke off if you want to try and attached the cables together in some fashion.
Regards,
Lenny
Old 12-31-12, 02:00 PM
Momscar
Momscar's Avatar
Regards,
Lenny
Thanks for the offer, hopefully I'll have the new one in 2-3 days. I probably could braze the 2 wires together if need be or you were around the corner.
Buy any chance do you know the part # ?
Old 12-31-12, 02:30 PM
vr4/sc400
vr4/sc400's Avatar
Sure........
http://www.lexussouthatlantaparts.co...975048010.html
Lenny
Old 12-31-12, 06:36 PM
Momscar
Momscar's Avatar
It's the lock cable which is above the handle cable on my door, But the grey fitting on my lock cable sleeve looks like the lower cable in the microfiche. See grey fitting in the photo before your microfiche.
That's why I was asking for the part #
Thanks thou
Old 01-04-13, 02:33 PM
Momscar
Momscar's Avatar
Default Fixed
Fixed, Thanks for the help.
This is the Part # for cable that goes to the red manual lock'
$15.12
$11.72
Old 01-04-13, 07:12 PM
carguy07
carguy07's Avatar
How much work was it to get to the other end?
Old 01-05-13, 12:05 AM
Momscar
Momscar's Avatar
Simple, you just need to separate the yellowish plastic piece from the white plastic piece 2 screws. The plastic pieces come out with the 30mm torx screws at the door jam, also 1 10mm bolt and the window frame slider will move out of the way. There's also 2 actuator bars that if you look inside the door you can see how to remove, twist and snap.
I used a good write-up for replacing the original lock motor, instead of doing the piggyback actuator, to remove the plastic pieces.
Abernoots
10-21-22 06:27 AM
SonicISF
03-18-17 06:53 AM
jsc8686
ES - 5th Gen (2007-2012)
03-07-12 06:08 PM
dtran023
09-18-09 04:05 PM
Slow_Sc3
SC- 1st Gen (1992-2000)
02-14-09 03:24 PM
Quick Reply: Door won't unlock manually or with piggybacked actuator?
