Valve Cover Gasket Replacement - how hard?
Old 03-22-17, 09:10 AM
  #46
Roop10
Roop10's Avatar
Default Part # for the new version of the rear valve cover?
Originally Posted by JAB
Salim: What I ended up doing was replacing the entire rear valve cover with the 'new' version that accepts a screw-in PCV valve rather than the 'press-fit' plastic elbow of old. The new valve cover included pre-installed spark plug tube seals. I tried to change the seals in the front valve cover but gave up and reinstalled the valve cover with the old seals still in place. I figure that if they ever do leak it will be a simple enough job to replace the front valve cover with a new assembly.
Do you happen to have the part # for the updated valve cover that you purchased? I've got the gasket set to replace the valve covers and spark plug tube seals but I'd like to go ahead and get the newer design so I don't have to worry about the rear valve cover leak issue when I redo everything.
Old 03-22-17, 10:35 AM
  #47
JAB
JAB's Avatar
I'll try to find it. Follow up in a day or so if I don't provide it.
Old 03-22-17, 07:21 PM
  #48
Lexmus
Lexmus's Avatar
The RX330 rear valve cover is 11201-0A060. At LPPParts.com this part comes up for RX300 as well as the RX330.
JBSGROUP (10-12-23)
Old 03-23-17, 05:48 PM
  #49
shervink24
shervink24's Avatar
This was recommended to me by a mechanic to have my valve covers changed. He said all the oil caked on the motor was from leaking valve cover. Im at 175K miles but I am not losing oil, and the car is driving amazing. Another mechanic friend said to ignore it and just drive the car because I am not losing oil. Are you losing a lot of motor oil which is why you want to change the valve covers?
Old 03-23-17, 09:46 PM
  #50
salimshah
salimshah's Avatar
Received 1,050 Likes on 948 Posts
If the gasket is leaking .. with the milage you have it most likely it has shrunk, then simply replace the gasket. If you are burning oil via PCV then put a catch can to confirm and then take the necessary steps.
Salim
Old 03-24-17, 08:26 PM
  #51
hsmac
hsmac's Avatar
my vcg's were leaking too due to loose bolts. i tightened ones i could get to on the rear and no problems since. i changed the front just because i wanted to check the engine and the gasket was a little brittle but in adequate condition. i wouldn't hesitate leaving the factory in there as they are really high quality material.
Old 03-24-17, 09:55 PM
  #52
salimshah
salimshah's Avatar
I agree with you hsmac, my oservation is that after about 100k the gasket needs replacement. For sure try tightening the valve cover first and if that does not work then replace them. Felpro also makes good valve cover gaskets.
Salim
Old 03-25-17, 12:41 AM
  #53
hsmac
hsmac's Avatar
Salim
you'd be surprised what really "needs" to be replaced but i know from experience that you prefer to replace parts like these. my tranny pan gasket has a tear in it yet still functions properly (and it looked new when i removed it i think it tore when i accidentally over torqued the bolts). the factory vcg is very durable and though the one i removed broke when I bent it, I have no doubts had I not replaced it there would be no issues. these gaskets are bolted down so tightly and there really aren't any objects that can prod them that would cause them to break. i'm not suggesting to neglect gasket replacement, but i'm not going to touch my rear vcg unless i have to and am willing to bet it will last for the full 200 or 300 miles that the car gets.
also my drain plug washer was extremely uneven yet it did the job the same even after i reused it. i did change it since i bought another washer but really didn't need to.
Old 04-28-21, 07:14 AM
  #54
JabobJeff
JabobJeff's Avatar
Here's another DIY video that may be of some help...
harrisbaig
15
04-28-21 08:22 PM
TriniLex
02-25-18 10:47 PM
maniax
22
07-04-15 06:26 PM
lexo98
07-05-12 03:49 PM
JoeInHNL
10-28-11 07:58 PM
Quick Reply: Valve Cover Gasket Replacement - how hard?
