No sound from the audio system
Old 02-14-13, 06:00 PM
salimshah
salimshah's Avatar
Received 1,063 Likes on 957 Posts
Originally Posted by AllBlakLex
I just read the other recent post about the cd player not working and it seems like they are having a similar problem. I wasnt aware of a MUTE button but the g/f says she has tried pressing it a bunch of times with no success. How easy is it to swap out a head unit if that is the culprit? I could easily DIY, but what is the cost of a used one?
Can you even rig up an aftermarket headunit with the way the dash electronics are set up in these cars?
With mute engaged, the display works as normal and radio tunes ... but no sound.
The Amp is in the trunk area. A competent car stereo shop can check the signal at the amp and voltage.
I would get that checked out before trying repairing (getting repaired) or buy a used one. 2001 or 2002, the head unit got a slight upgrade, but cosmetically and fit wise it is the same as '99
Salim
Old 02-14-13, 06:12 PM
iolmaster
iolmaster's Avatar
Presets and tuning work fine. All functions of the LCD screen work. Just no sound. No sound regardless of source.
Old 02-14-13, 06:30 PM
JAB
JAB's Avatar
Is it a Nakamichi system, or the standard?
Old 02-14-13, 07:14 PM
salimshah
salimshah's Avatar
Have the audio level tested at the Amp near rear seat and trunk.
Salim
Old 02-14-13, 09:17 PM
gazi001
gazi001's Avatar
Can you tell us details about the radio Pioneer or Nakamichi and for RX?
Old 02-14-13, 09:22 PM
gazi001
gazi001's Avatar
Check the amp. Sounds like it bad.
Old 02-15-13, 03:04 AM
iolmaster
iolmaster's Avatar
It is the standard audio system and it is in a 2000 RX300.
Old 02-15-13, 10:02 AM
99rx
99rx's Avatar
Post a picture of the screen and let's see what it's doing.
Old 02-15-13, 10:04 AM
99rx
99rx's Avatar
Head unit sounds fine, sounds like an amp issue.
CajunRosa
06-04-24 05:16 PM
rmbhagwa
RX - 3rd Gen (2010-2015)
34
09-18-23 05:31 PM
TigetJacks
LS - 5th Gen (2018-present)
04-22-19 05:22 PM
Paulanth
ES - 6th Gen (2013-2018)
01-20-19 07:51 AM
Shelby2011
GX - 1st Gen (2003-2009)
02-18-13 03:35 PM
Quick Reply: No sound from the audio system
